VFD conntection to IoT relay resets Masso controller
Wired the IoT relay as per the PWNCNC video instructions. Checked to make sure the harness was built correct. When the spindle was set to 6000 rpm a brief signal was sent to the IoT then Masso Control reset power causing a restart. Anyone have a solution??
Can you provide a napkin drawing of everything plugged in where annotating circuits?
