Spindle Speed Doubled
I’m running a spindle warm up program on a newly assembled conversion kit. I’m seeing spindle speeds that are always double the requested S1234. Is there something to correct/check on the Masso or VFD?
Additional troubleshooting steps:
I set the spindle speed to 7000RPM and started the spindle going clockwise. I then checked on the VFD and it’s showing 226.5Hz and around 13600 RPM.
Change p2.0.15 on the vfd to 10.
Masso uses a 10v signal, shapeoko uses a 5v signal
That did it, thank you.
