I ordered an 80 mm air cooled spindle kit and received a 2 pin male adapter from the vfd to my cnc controller which has a 6 pin connector. I ordered a new cable figuring I just had gotten the wrong cable and it’s the same one. How is this supposed to work?how does that 2 pin connector connect to the 6 pin connector comming out of my cnc controller. I can’t get my cnc up an running until I get this sorted out.
Ni Nick,
I believe this is the information you’re looking for.
Installing Warthog Pigtail
You don’t need to have every pin to be used, and they’re made like this to be semi universal. My old SO3 had the 6 pin molex, and there was only 2 pins used on that as well.
The Onefinity Buildbotics is the only controller that uses the 2-pin port on the VFD, but the Elite with Masso uses no more than 4 at one time, and the reason is how its wired on the inside which only requires a reprogramming to move from one machine to another.
Thanks for your email, I came across this earlier today.I can finally finish connecting my spindle and fire up my cnc!
