Switching spindle and vfd from one brand cnc to another brand cnc
what is needed to make the change
A new cable, and parameter change possibly. Send us an email of which machine you have, and which machine you’re going to and we’ll let you know what parameters need changing
Hello i have the 2.2kw 220v er20 80mm 2-pole 400Hz water-cooled on a Shapeoko Pro and im looking at the onefinity Elite Foreman so im checking to see what i would need to do for it to work Thanks Rob
If you have the pro, you might already should have a gx12-6 pin to gx12-6 pin cable. If it’s the one with a molex, you’ll need it found here
Then it should just be:
p0.0.03 to 1
p2.0.02 to 21
p2.0.15 to 10
