Adapter to use vfd off masso on bb
I have a onefinity with the bb control. My brother has the elite masso. He has been running the pwn spindle kit with his for a year or two. He is upgrading and is giving me his setup but will it work with my bb control? I need a box or adapter right?
This article will help as far as hardware, but it’s set for people opposite your situation.
At the minimum you’ll need a cable:
And set p0.0.03 to 2, and p0.0.04 to 9.
His will read 1 & 3
I was able to use manual at first but today I changed some parameters I watched from a pwn video setup on a bb controller. I did those settings but that didnt work and now my manual switch doesnt work . Stupid me did not write my settings before changing so if this happened i could just go back and wait for pwn support to respond.
Which video did you watch?
Daniel was showing the settings for the bb controller . Id have to find it again . I submitted a support ticket back on 12 -22 and ordered the cable recommended but have not heard back yet on how to setup the vfd. Im struggling here and having to go back to my router. My manual override worked until i tried the settings in the vid , now that doesnt work either
I’m willing to bet you tried the old settings.
I only told you to change p0.0.03 & p.0.0.04
Here’s a link to the install
Probably , Im sure I changed the wrong parameters.
Well, Onefinity uses the same vfd and spindle… if i was you i would look in the Redline manual for the buildbotics vfd settings
Im confused about what your telling me. This is a pwn vfd and spindle. It was bought and used on a onefinity elite. I bought the cable pwn said i need which was the modbus. Then they said I just needed a walk through on settings. That is what im waiting on with support.
I understand, i do.
Onefinity sells the same vfd, and they have the vfd settings for both buildbotics and masso in the manual.
