I have a spindle kit (1.5kW, 110v, 80mm, 2 pole, water cooled) installed on an AltMill along with the 300W braking resistor. As far as I can tell, the VFD behaves as if the resistor is not present. Is there some parameter that needs to be changed to enable the external resistor and allow for ~3 second deceleration times?
Current observations:
- The spindle deceleration time (P0.0.12) cannot be set lower than ~4.5 seconds without causing Err06. This happens regardless of whether the resistor is connected.
- The resistor leads are connected to the P+ and PB terminals of the VFD, and a multimeter shows 250 ohms across the screw terminals.
- With the resistor connected and a deceleration time of <4.5 seconds, no voltage is measured across the P+ and PB terminals at any point during the attempted deceleration (so no current is passing through the resistor).
- The displayed bus voltage (P9.0.04) is 182V at 0 rpm, 179V at 24000 rpm, 228V when braking from full speed with P0.0.12 = 5.0 seconds, and >242V when braking with P0.0.12 = 4.0 seconds before throwing Err06.
