My spindle will not come on when using auto mode. I’m using carbide motion and have reset everything, the spindle does work in manual mode just fine. What could be the problem?
Carbide Controllers are unable to trigger the “forward” function of our VFD’s. You’ll have to hit the “RUN” button then start your program.
Alternatively you could use our new “auto-forward” program settings… https://youtu.be/SvAJuFM4eqE?si=2Ir36Eb8dEX9Dq0y
You guys are Angels!!! Just modified the spindle kit and everything is working 100 percent!
All fixed!!! You guys are Angels!!
I just upgraded my 65mm spindle kit to the 80mm and just applied these changes !!! This is fantastic.
Thanks for all the hard work in making our life easier.
