I installed the 65mm water cooled spindle a month or so ago and reconfigured the VFD for the auto start option. Everything was fine and a I used it for a couple of weeks on various projects.
I had the machine off and unplugged for a couple of weeks due to issues from hurricane Helene. Yesterday I powered back up and noticed tried the quick actions for spindle
Warmup but it would not turn on. I tried a simple test cut on air and the same thing. I eventually switched to manual, cycled through some speeds switched back to auto and things worked as usual.
Same experience today.
I usually turn the VFD on before turning on the CNC and initializing.
Is there anything I should do differently after a prolonged outage?
Did you program the VFD for automatically going into a run state?
If not you need to hit run to put it in a run state. I have a suspicion this is your problem.
If you want it to do have it go into a run state automatically, here’s a video for you.
Unfortunately, there is not. If you have a V5, can you remove the switch and connect the two leads on the switch to make it automatic all the time, but that should be a test. It also could be a loose lead on the switch. This again, this is still behavior I haven’t heard of before.
I just did some messing with it and it looks like the display is showing 5 +/- v all the time even with the CNC turned off which surprised me. Maybe I am misinterpreting the value.
I will mess around with it later. This time I did the manual spin up and then tried from Carbide Motion and I got nothing so it may be more perplexing than I had hoped.
If its reading 5v “all the time”, hmm thats weird. If it was whenever you commanded over like 800 rpm’s it went to 5v, I know what that is… its bit runner, but I don’t know if that issue applies to the SO 5/5 pro. I thought itd only apply to machines where we plugged into the bit runner port.
Thanks. I will check this out later this evening.
I will also go through the auto run document and revalidate than have the settings correct.
I have the Pro, not the 5 Pro.
I did have a BitRunner and disabled that when getting the VFD set up initially.
It worked fine until I had it off and unplugged for a couple of weeks.
Is there a preference to turn the VFD on before the CNC or after?
