Shorten or cram?
The motor and sensor cables are longer than my set-up requires. In the attached picture, lines from all 4 meet beneath the surface on which the Dominator rests. The Power Box will go on its own shelf, exactly where these cable ends are. The Masso will go on a stand above the table surface, taking some of these cable ends, but there will still be a lot of extra length.
Options:
  1. Leave all of them draped where nature takes them (dust, tripping, snagging)
  2. Jam them together in a tidy mass (interference?)
  3. Secure cleats under the cabinet to wrap excess cables in loops. (also interference but less?)
  4. Cut to shorter lengths and:
  • Re-solder the pins on the aircraft connectors (ugh) or:
  • Restore each wire on the motor and sensor ends (ugh 2)
What would you do?
Isn’t the other end bare wires in a phoenix or terminal connector on the motor?
Clipping the wires and soldering them back together would be more preferential to trying to do the connectors
