Setting up Fusion for 4th axis
After purchasing the rotary attachment, I’m attempting to set up the 4th-axis in Fusion.
I’ve set up the post-processor and set “Fourth axis mounted along” as “Along Y”. But once I attempt to post-process I’ll get either:
  • “Error: Direction is not supported for machine configuration.” when I don’t check “enable 5th axis”
  • “Error: Cannot have fifth and fourth axis set” when I do check “enable 5th axis”
Are there documents or notes available to help get things up and running?
Hi, I’m new here. I don’t have a 4th axis yet, but I’ve been playing with Fusion 360 for a while. Have you edited your machine’s mechanics? Are you trying to set up 3+1 toolpaths, or did you buy the Machinist Package to do full 4-axis machining?
I had to manually edit my machine’s post post-processor, This is the video I followed for it (i think)
I have the full manufacturing extension, so I can do 4-axis machining.
The Masso post-processor definitely supports 4-axis natively and I’ve set it in the post dialog for the tool paths:
I have not changed the kinematics of the machine, though, because I’m not sure where the rotary should be placed in the kinematics screen.
What machine are you using?
Where do you plan to put the 4th axis?
It’s a pwncnc conversion kit (Masso controller) on what used to be a Shapeoko 5 Pro 4x4
The 4th axis will run along the Y on the left hand side of the bed.
I’m using a Onefinity, but as I said, I don’t have my 4th axis yet. I have no idea if this will work for your setup. But this is what my kinematics screen looks like.
As I said, I have no idea if this will work out.
but it generates gcode with A moves
I googled this error and found several possible solutions from wrong post processor to file doesnt require a rotary
Do not check 5th axis because im pretty sure that’s the C axis not a slaved B axis
I wish i could help more, but I’m using vectric not fusion
Thanks to y’all I was able to get things to post. Here’s what I did, in the hope that this helps someone else later:
  • I deleted the machine model - it’s not like I have a model of the machine to simulate with.
  • I unchecked the 5th axis in the post.
  • I created a manufacturing model oriented along the axis that I’ll use for the lathe.
  • I deleted the set up and started fresh with a “Milling” set up.
Now I can post. Next step is making sure I don’t run into the lathe. :stuck_out_tongue:
To mitigate this, I first utilized a work offset dedicated for it. The headstock being on the right thing is the reason why. I then modified the post processor to change to the work offset and go to the orgin.
I don’t know how much or what you can customize with the post processor in fusion but here was a basic list of things I’ve done with mine
Fusion will let me supply areas to avoid as a fixture, so I’ll set up a rough model of the rotary in Fusion, just to make sure I avoid it.
Thats probably from the work offset, and I couldn’t imagine it using machine coordinates to establish the “no-go zone”, so while that sounds like a protection, it’s not a failsafe.
You could setup your machine coordinates to correlate to your working offset, but that will making zeroing on your rotary more challenging, but you’d only have to do it once provided you have established a way to setup your rotary in the same location. This is obviously talking about the occurrences between powering on, and setting up job. With the headstock on the right, I just have to make sure that my xy is on the left side of the rotary, and I can hit go, and it’ll automatically go to the rotary xy0 before cutting.
If your motor isn’t rotated 90 degrees out of the way, I would suggest doing that as well
