I’ve got my rotary hooked up and everything seems to function, but Even though I set my F1 page to the settings shown in the KB, The readout doesn’t really make sense. On the screen I get about 13,000 degrees per revolution…it’s hard to see because Masso cuts off the the first 1 1/2 digits. It rotates very quietly and smooth, but it’s very slow. Also when using the handwheel, it doesn’t seem to register unless I crank the wheel very slowly. And I see that the light on the motor doesn’t come on…I’m assuming it’s a light…?
Edit…I switched it to the setting shown here…
And now everything seems good. Still no light, but I’m not even sure if it’s a light.
Glad you got it taken care of.
I was going to have you command a 360° revolution if that didn’t result in 360° movement, have you take the cover off and verify/set the switches.
That was going to be my next move but everything’s cool except for the motor light. Haven’t cut anything yet but I did put it through some paces. Very happy with it. Better fit and finish than expected. Nicely done!
