Just ordered a onefinity Journeyman for Wall mounting. Also a PWN Spindle 110v 1.5kw air cooled.
Awaiting delivery.
Im anticipating having the cnc x axis horizontal (not recommended by onefinity). Will build counterweight system to take any stress off y steppers. Should be cool!
Any Comments? Anyone with experiences to share?
Anyone doing this in NY?
I would love to see the progress as you make this happen. What’s the motivation for wall-mounted? I’m assuming space.
For the 110v 1.5kw 80mm spindle, it’s heavy but the CNC machine “should” be able to handle it. If worst comes to worse, you might consider replacing the Y motors with stronger ones.
The X gantry is really heavy on the larger machines. iirr nearly 125lbs by itself… then add the Z carriage and the motor. You’ve got a lot of weight to lift up there.
