Masso upgrade! inlets panel!
Want to dominate your Masso Touch? Check out our latest upgrade, the “Inlets panel”!
#upgrade #cncowners
#cncmachining
#cnc #maker #makers #onefinitycnc
As a new user an actual alarm killer (reset) would be great. Put me on the list to buy.
If you were using the top connection on the inlet panel, How long of wire would you need to make a connection to the top of the MASSO?
Maybe 30" but there are ports on the left and right side and to utilize all 24 ports would take a lot of inputs and outputs. We’re offering 25" leads currently on our 2/3 pin connectors.
Personally I’m planning on using a dozen or so, and I have a lot of accessories. Could see the need for more if I wanted to rewire the whole thing from the molexes
So I’ve installed the Masso relay module, will this get in the way of mounting the inlets panel?
