Masso CCW not working
I have ordered the ATC system from Onefinity, in order for that to work I will need the PWNCNC spindle to run in reverse. Currently if I press the CCW button it does not turn on. What do I need to do or check to make that work? Any help would be appreciated!
My current setup is a Woodworker that I upgraded from Buildbotics to the Masso.
I don’t know the answer. This article may have what we are looking.
https://support.pwncnc.com/kb/article/144-onefinity-elite-masso-wiring-notice/
I checked my spindle last weekend for the CCW option and noticed the same issue. The link that Maymunbaba provided corrected my issue. The white wire needed to be placed in the correct position.
Thank you, that did correct the issue. I had seen that link the other day and apparently did not look hard enough for the taped off white wire. It was tied neatly behind some other wires. After your post I went and looked a bit closer and it was there.
In case you are like me and want to know all the options for potential dust boot for 1F ATC. This is to more my liking avoiding “air”:
I have been looking to se what might work. That setup looks pretty sweet. Are you planning on selling those? If so will they work with the Masso?
I have no relationship with the designer, just a user looking for my options and sharing what I found out.
Expectation is that Rapidchange will carry them…soon…
It worked. In my case the blue wire was not connected. I had to wire only the white one and change in the VFD / P2.00.01 from 43 to 2.
This is a PERFECT example of PWNCNC’s customer-focused approach. While OF is trying to FORCE people to ignore their previous suggestion to buy PWNCNC’s spindle and buy their new REDLINE (which is exactly the same as PWNCNC’s I think), Daniel and his team are focused on helping people make things work. Go PWN CNC!
