ATC DustBoot Compatibility
Greeting all
Fellow Onefinity Elite Forman Owner with a PwnCnc Atc spindle.
Curious one what DustBoot is recommended or works well. I’ll be using the flush mounted tool holders along the x axis
I use the v10, but not the flush racks and use the tall racks. The flush racks are unlikely to work with a z dependent boot because the motor has to go low enough to catch the holder.
Worrying about clearance on the x axis with the v10 is less concerning than along the Y which would have to account for the forward spacing.
With the flush racks, that’s best used for z independent boots like v3/v9, but there is a minimum height that your boot must be at or above to clear the top of the holders, which means you’ll need to have your thinner stock elevated.
