I purchased the 3d file for the VFD Keypad Mount and I was wondering what size/thread/length screws are needed to mount to the back of the masso display on the 1finity elites? I haven’t received my cnc yet, but was going to make sure I had the right hardware on hand for when it came. Thank you in advance.
Masso takes an m3 in those holes. On the inside its where the relays go. 10mm or 12mm should be enough, but i don’t have the masso mount given it doesn’t fit my workflow.
Thank you so much Chris, you are amazing!
Thank you, I do try.
Rizzo, I went with the same VFD remote mount. Just be aware that once mounted there you have to remove it to open the Masso controller screen/door. I ended up using CA glue to attach it to the same spot without impeding the door/screen.
FYI
