Cable joints. Intended for ATC, but will work with water cooled just the same. A set of 4 will be included with ATC orders.
A Yellow MTC Handle will be included with your ATC System. However, if you want a black one or a spare this is the piece for you. Made of petg with a fuzzy texture, they’re comfortable to hold and easy to place
Masso VFD Mount & Manual Override Switch. Used to mount the keypad on the Masso unit with relocating your manual override switch. Don’t forget the manual override extension cable & vfd extension cable
If you already have the masso vfd mount, the surface mount with mos is the one you want.
If you’re looking for more protection for your Masso screen, we have tempered glass screen protectors. Installation instructions coming soon, but it’s an oversized cell phone screen protector.
If your looking to relocate your Masso unit on your Onefinity Elite away from the front left where it natively homes, this Controller Mount is for you. It’s a 3 piece unit featuring a base, carbon fiber tube, and top that allows you to use the stock aluminum arm away from the corner where it homes.
Do you have the lube cube and want a way to hold the line in place? Compatabile with the PwnCNC Spindle Mount and Shapeoko HDM.
As always makers files are available:
Elite Mount
MTC Handle
Mister Mount
Cable Joint
