VFD cycles were not working
Good afternoon I am new to this my 80 mm air cooler VFD cycles for 30 seconds Ish three times an hour when it’s not working is this normal usually the machine gets turned off and I leave the shop but lately I’ve been hanging around and noticed it just cycles thanks
Are you hooked up to a gfci?
Just because it’s not plugged into the gfci outlet doesn’t mean it’s not on a gfci circuit.
I forgot to mention it’s 220 has its own dedicated line and he has a picture of the breaker
thanks
Can you clarify what you mean when you say it cycles? Also what kind of controller/ machine you have?
On the controler it sound like the fan turns on for 15 seconds and then stop and it happens about every 20 minutes but have not time thanks
The fan turning on and off is normal. Need not worry about it.
Thank you Chris I appreciate the help
Peter
