2.2kw 220V water-cooled spindle/VFD problem
I just built a Onefinity Foreman Elite and I opted for the 2.2kw 220V water-cooled spindle from PWNCNC. The machine is built and I could not get the VFD to come on. I did everything I could and it wouldn’t work. I figured I got a clinker and they sent me a new one. The new one is doing exactly the same thing!
I was told I have to force the power plug into place because it’s hard to do. He said, “Force it, you’re not going to break it”. I did, and I did! Am I wrong to think the display should light up when powered on?
Everything is plugged in as it should be and there is 220 power at the plug.
You’re not wrong in that the keypad should illuminate when powered on. Might take a
couple of seconds, but it’ll happen.
Is the keypad by chance plugged into the vfd and fully seated, or did you use a crossover or home made cable to extend it out?
No, it didn’t power up before removing the keypad. I removed and reinstalled it several times, but still nothing. On the replacement, I used the supplied extension cable. I feel like an idiot, I know how to plug in a device and turn it on.
I figured it out. It looks like Sparky used a TANDEM breaker, not a 2-pople. I’m off to Home Depot. I think I’m going to demand some of my $2700 back!
That is a 2 pole breaker not a tandem breaker unless I’m not seeing something.
Why a 15a I don’t know, and I’d get a 20a one instead.
I doubt that’s the problem. It’s best to have the outlet/receptical rating match the breaker rating, and the wire guage for both equal or greater.
I talked to an electrician buddy of mine and checked a few things. It sounds like they charged me top dollar and he took the lazy/shoddy route. I will be having a serious discussion with them tomorrow. I don’t know exactly why it’s causing a problem, but my buddy says he was lazy and only tapped one side of the main panel to feed the subpanel and that’s the problem. In the subpanel, I read 117V between the ground and each leg, but zero between the legs.
Now that I have opened the new sub-panel and original service panel to discover what kind of a hack-job was done, I have a bargaining chip to insist that they take care of a few things that I suggested but they didn’t want to do. I suggested moving just a few of the circuits from the filled-up service panel to the sub-panel to ease the space in there a bit. I’m going to insist on a different tech also. I don’t want that hack touching that panel again!
