Tool Setter with ATC?
Hi all! I have a 1F Elite and I bought it with the Easy Z tool setter before realizing I was going to get the ATC. Do I need this?
It seems that once the tools are in the collets, the Masso should remember the z-height of the tool, no? Or does it want to check the tool Z every time it picks up a new tool?
It will still need the offset lengths which can be done with a probe, but it is easier to do with a setter.
I have 30 some odd bits, and regularly use about a dozen of them. When i change them out, it’ll have to get that offset because I’m not wanting 30 some odd holders.
It’s not a bad thing that you have it, but it’s not going to be used as much after you get your initial offsets, if you choose. You still can touch off after every bit change if you wish.
