PWN CNC Spindle Connection to Acorn Controller
Hi everyone,
I am seeing some assistance with making the VFD connection to my new Acorn motion controller witht he MX6 cable. I am converting my Shapeoko 5 Pro over to a Centroid Acorn controller and the motion controller has some slight connection differences from what I found on the pwnCNC knowledgebase. I will attach a PDF of the Acorn schematic for a “generic VFD” and the screenshot I found on the knowledge base for reference.
I am assuming the following connections…
(MX6 Cable to Acorn Controller)
Digital Common > VFD Common
Forward > Spin forward
Reverse > Spin Reverse
PWM > AN Out
GND > AN GND
10V > ???
shield drain > case grounding bus
You don’t have to use all the wires, and even with the masso controller we don’t use the 10v output. Other controllers (like shapeoko) only use pwm and ground
Thank you Chris. Do the remaining connections I have assumed look correct?
Based on reasonable assumptions, mostly yes. I don’t know if the shield ground going to the case is right though. If the board is grounded to the case, it’ll cause a ground loop. Some say it’s bad, others say not so much. I haven’t done a lot of research into the subject as of late, but id err on the side of bad personally. With masso we say to plug it into the ground port as well as the ground pin.
At a minimum you’ll need to change p2.0.15 to 10
Carbide uses a 5v pwm signal, and moving to a 10v controller will result in rpms at half speed.
We have an acorn, but haven’t done anything with it, so our Knowledge on it is fairly limited and we’re only applying what we know of other controllers, to it.
Thank you so much for the help. I will share whatever I find throughout the process on here to help with future Acorn users.
