I purchased an ATC system a year ago and am only now setting it up, everything seems fine except that I can’t seem to get air into the airline…the gauges are all at zero and when I pull the air line out of the unit there is plenty of air coming through the line…what am I doing wrong?
Please reach out to support@pwncnc.com for official support.
But the key is to get 90PSI out of the TOOL regulator. This means you need 90-100psi going in… so start there. Make sure you have a good supply of air going into the PE.
Then adjust the TOOL regulator until you’re getting 90PSI out.
Alternatively you could verify your input air by plugging it direclty up to the tube going into the TOOL port. This should retract the draw-bar in your motor and release the tool (or let you put one in).
But best solution is to reach out to official support for help.
