I have been testing our modbus controller with every VFD for correct connection before shipping, and they have all worked with our black-box controller. Hopefully everyone with this issue was able to get it resolved! Take care, Diana
Is that PWN answer to this problem Daniel? Now I have to contact 1F for support, I like others purchased Pwn for the āplug_n_playā and the local support. I had to wait 4 weeks for my spindle order and it does not play right with the CNC it is intended for. I spent most of last night opening up the BB to get to the SD card then the headache of finding and getting the correct 1.3.1 build to reflash, THEN put everthing back together only to see the āDisconnectedā message. Please help Daniel, donāt send me to the 1F email support~
Hi Clinton, Yes I saw that post, but mine had not the same outcome. All work just as the instruction, but the disconnected still stands. Has there been any further findings on this, or what am I to do now?
Thank you
When I turn on the VFD in auto mode the LED flashes 0.0, when I watched Danielās video his had ~ 1000 ~~ ish
Could this be something?
In a word the blinking number difference is NOT an indicator.
Have you followed the troubleshooting steps at the bottom of this article?
https://support.pwncnc.com/kb/article/112-onefinity-blackbox/
If it still doesnāt connect, send us an email at support@pwncnc.com with a video demonstration showing settings, connections, switches, and anything else that could be an indicator of the problem.
Youāre last paragraph is what solidified me choosing to buy your spindle kitā¦itās frustrating that 1F doesnāt even attempt to support them. Your support, by comparison, is outstanding and very welcomed to the āspindle noobsā like me.
CNC robotics, not newā¦spindles are for sure.
Good morning!
Received my spindle kit last week and started the install yesterday. I connected the modbus cable and it showed ātimed outā. So, per the other responses Iāve read, I attempted to switch the wires going to pins 13 and 14 in the DB25 connector at the Black Box. Iām still getting the same ātimed outā message after switching the tool back to disabled and then back to PWNCNC VFD. Iām running firmware 1.4.1. Anything you else you could recommend to troubleshoot? TIA
Weird your getting it both ways.
Have you tried anything else outlined Here
Just got the replacement cable. Hooked it up and instantly got an āokā on the connection status. Tried the M3 S6000 in the MDI screen and spindle spun up perfectly. Hit the M5 command and it slowed as expected.
Iām good to go and ready to butcher some wood with the new spindle!! Thank you and the team so much!!
so this might be a silly question but when you say flash is there a way you mite be able to help us run us through that process?
I canāt give you a step by step, but it means to reinstall the software, even if your preinstalled version is the current version.
Hereās the link to the latest firmware:
I think heās recommending using the USB method of down/upgrading or reinstalling the firmware. Itās described there in that forum article.
