you all know how as long as Daniel was providing support to Onefinity’s customers, he had Onefinity’s goodwill, but when Onefinity had learned everything they needed from him to replicate his spindle/VFD product and offer it themselves, they behaved like described in the “Onefinity Forum Censorship” thread here in this forum.
As you know I’ve been thrown out of Onefinity’s forum for having pointed a disappointed Onefinity customer to the fact that PwnCNC’s product is in stock.
Now as a non-member I still follow their forum and I observe that Onefinity customers are very dissatisfied, first because of the many monthes long delays that they have to wait for their product after having paid the entire price in advance, but here also as it seems by a VFD enclosure design issue:
so this seems simple but there is nothing to attach it to the table with. no angle brackets no obvious holes to insert screws. nothing on any videos I have watched. Also no owners manual but I am used to that it is probably online.
WHO ARE THESE ENGINEERS ANYWAY? REMINDS ME OF THE COMMITEE DESIGNED HORSE. weird that we have to come up with common sense fixes nearly every time we get a product. maybe we are being too hard on them as these are new products. But it seems weird that it is nearly every product we pay good money for has some simple to fix flaw that should have been spotted at the first or second engineering meeting..
@Daniel, since I don’t have a specimen of your VFD enclosure, how is this with the PwnCNC VFD enclosure?
There’s 2 ways. A French cleat (included), only good for vertical mounting. And a mounting bracket product option where you can mount it virtually anywhere
Caution! The equipment is intended for installation in a cabinet. The end application must be in accordance with EN 60204-1. Refer to the section “Choosing a Mounting Location” on page 29. The diagram dimensions are to be suitably amended for your application.
Option of the installation space:
When the EM60 Series Frequency Inverter is installed vertically, sufficient heat elimination space shall be provided to ensure effective cooling.
Installation space of EM60 Series Frequency Inverter
Attention
Seems to imply that you may mount it horizontally?
The manual is funny as it says it needs 100m / 150m clearance. I don’t have access to see how many mounting brackets or maker files have been sold, i do know the vfd comes with a 20 month warranty, and i do know that while i was employed with the company i hadnt heard a complaint rooted at being under the table, or overheating where the environment was hot
It doesn’t say you can’t mount it horizontally or under table. If the fan draws air in and push it out, i don’t see why you couldn’t though.
My thoughts exactly… imagine how much that spindle cable would cost!!
This is also version 4 of the manual. When i bought my spindle kit back in 2021 or so, it came with a hard copy manual. I would comnstantly reference it with support tickets. I got irritated because my version 0 manual was different than the version 4 manual found online wasnt aligned. I did ask Daniel to send me a hard copy of version 4, which he did, and the hard copy finally aligned with the pdf found here. It was like scratching an itch you can’t reach.
After being away from the Onefinity Forum for some time, I wondered why I hadn’t seen any of your posts except from far in the past.
I happened across this forum while researching a little about Onefinity CNC complaints (actually having to do with censorship on one specific safety issue).
It has been noted that there appears to exist a condition where the Redline controller and spindle may not be shut down via the emergency stop button. Though my machine is still yet not fully assembled, I took note that this is should be a major concern to everyone having this cnc system.
Redline has responded with concern and a rather weak explanation for the phenomena pledging to provide a work around. On the other hand, Onefinity dismissed the problem saying users should exercise caution with the spindle and “wipe their hands”, so to speak, stating it is a Redline issue not theirs. On top of that they deemed the thread “solved” and removed it from their forum page.
My point here is, if they learned from PwnCNC about developing their own product they didn’t seem to pay close enough attention. So yes, it is disconcerting to experience censorship by their moderators but much more so surrounding discussions concerning some severe safety issues and simply out of hand.
Do I just wanted to let you know that In the past on that forum you were highly regarded as a consummate expert, but now that I know you were banned for crossing some line it is likely it will trickle down to others there as well.
Who saw this coming!!! I did… Redline is Onefinity, but they don’t have enough faith in it to brand it Onefinity.
Just through reverse engineering… but when they created a new black box controller with a touch screen, they obviously introduced bugs.
While it hasn’t been updated in sometime, and he hasn’t been here I hope hes okay. Last I knew he was moved, and he was showing me pictrures of his new crib, but that was about a year ago, sometime after onefinity went extreme manipulated / censored
