I have a onefinity journeyman pro with buildbotics controller. If I were to purchase your Core Upgrade, 2nM meters, pendant and tool setter, what would the identity of the upgraded cnc be while using Vectric Pro of Aspire software be?
Yours. Machines don’t identify as anything else
In Aspire you need to select a manufacturer, machine and post processor. Would I select Infinity, Elite Masso, Journeyman or would PWNCNC have their own manufacturer, machine and post processor which as of today does not exist in Vectric’s database?
Your best bet is masso atc arcs which is the root post processor i use. Sorry I misunderstood your question.
I say root because I modified the header and footer some to do things that I want
Selecting the manufacturer and machine you speak of i believe only relates to the tool database, and if you only have one machine this is less important. If you have multiple brands machine then you would do it for the frame it is as aspire couldn’t care less about the movements and frame
IMO, it’s unlikely that PwnCNC would ever have their own post processor and would instead differ to the controllers (Masso) post processor. Why re-invent the wheel?
