In tool configuration my connection status says timeout i have onefinity woodworker with blackbox controller
Have you tried swapping the cables in the breakout board according to the control cable guide for onefinity w/ buildbotics?
I dont know what you mean
The breakout board is the box/connector that goes to the Onefinity black box from the vfd.
There are 2 screws that hold it together. If you remove those screws the top will be able to be removed. You’ll see a series of terminal connectors, and it’ll require a small flathead (and maybe tweezers) to swap the 2 wires, i believe their 13 & 14. Swap them and close it back up and try again.
When you open it, you’ll see what i mean.
That didnot work still says timed out
I finally got it it. It is working now
