I purchased the ATC with a 220 water-cooled spindle. The spindle was not letting go or pickup the tool when I used the t_m6 command in MIDI.
I have received a replacement pneumatic box. We’ve swapped them out and there’s still no change. We have tested the compressor and we have enough pressure. We’ve metered all the lines and all the lines are good. We still have when in auto it doesn’t drop the tool and goes over to pick up new tool but doesn’t pickup, either . when using the t_m6 in MIDI. It works fine when we push the button to drop and open the jaw on the spindle. And it picks up when we go to pick up when we use the MTC button
interesting, can you demonstrate what works, and your process for what doesn’t work in the video? please include the f1 screen and a pic of your wiring inside.
Low is irrelevant at this point. The “yes” is more important than the low. This is what it should look like on the F1 screen for those input/outputs. you probably don’t have anything in output 6.
If you highlight output 7, and change it to high by pressing the spacebar it is supposed to blow air, and eject any installed bit (so do it either empty or ready to receive it.
Side note. Don’t use long bits “in the back” because they could crash with bits as it goes forward. At least check your heights for this, and theres no danger (or at least the least amount of possiblity for a crash) in going z=0 between tool changes.
