3 Phase 208V, will this be ok for my new 2.2 Spindle?
My shop is wired for 3 phase 208v. I searched and could not find any info on if this is okay or not. I suspect it will be fine as I run all kinds of tools and equipment in this shop without a problem but I just want to double check before I hook everything up. Thank you!
I believe i responded to your inquiry, but best advise is consult an electrician and give them the power requirements below
I’m refusing to answer one way or another because electricity kills, and i know enough to do most things myself, but not comfortable enough to give advice. This is something i have no clue about, because the VFD converts single to 3 phase, don’t know what happens when to start with 3 phase
https://support.pwncnc.com/kb/article/15-what-you-ll-need-to-power-your-2-2kw-220v-spindle-system/
