Y binding. Are shims the answer?
A new 3x4 Dominator won’t bring the gantry far enough forward to reach the tool setter. At 1.56" the Y motor stalls. If moving too fast or trying to overcome the stall, Masso flags an error and stops.
The spoilboard is removed, and nothing is striking the carriage or ball nut. The nearby Y-cable chain is not tugging on the gantry support there. With motor removed, I can turn the ball screw by using a ring plier in the red plastic piece, but not by hand. In that last 1.56" I can’t do that.
A rafter square resting on the gantry shows that both gantry supports angle ‘in’ toward the center by about 0.5 degrees. Measuring distances from the outer edges of the supports, I get 1494 at the top, but 1491 at the top of the table extrusions. (It must be narrower still at the bottom, but I can’t measure there). It seems to suggest that the screw and rail aren’t perfectly aligned. It copes over most of the distance, but at the front the argument is more than the motor can handle.
First, I don’t know if I’m right. I don’t know how to get more precise (or useful) measurements. But (second) if I am right, I don’t know what to shim or move. Attached is a diagram, and letters to refer to three places where a shim could be placed. A fourth place (if the screw should move out) is under the ball screw mounting. If the gantry supports “want” to move outward, and the carriage is the least flexible piece, then the ball nut (at “C”) might be pulled away. On the other hand, the position of the ‘near’ end of the ball screw is rigidly set only at the ends.
I’ve considered putting a support under the gantry support, loosening the pieces attached to it, and finding out where everything ‘wants’ to go.
Opinions?
Assuming the design is the same (pretty sure it is), the length of Y is irrelevant. The orgin point is Y0/X0 designated front left. The X and XZ have more to do with it, but that’s assuming your needing to do it off table.
I just marked a spot with my vbit and put the tool setter there when i need it. I do have ATC and manually call for a change when needed
Perhaps you are referring to the “Touch Plate”. The “Tool Setter” has a defined location, bolted to the front Y-plate, and it isn’t moved. The problem of reaching the front of the Dominator will also prevent me from using an ATC in the front.
I know you did a mock up in cad of some kind, but actual photos might help because i believe you, but need to see what your referencing
I made a video of the problem yesterday, and a still image (today) of what might be a solution.
My first effort was to loosen the bolts of both the Y and B front plates, bring the gantry forward as much as possible, and tighten. That bought me an extra 3/8", but still too little to reach the fixed surface of the Tool Setter.
Today I loosened the bolts that hold the left gantry support to the two carriages that ride on the rail. I remembered how, when installing them, the bolts were pulling hard to become fully seated. That tension was released by loosening them, and the still image shows the gap created. (I put a red shim in the back to make it clearer to see).
The carriages sit in a dado in the gantry support. Feeler gauges tell me that the gap from the bottom of the dado to the carriage that sits in it measures 0.090" on the rear carriage, and 0.072" on the front one. The average of the two equals 2 mm.
While the tension was released, but bolts were still keeping the parts aligned, I slowly jogged forward and got to the position it’s supposed to reach. I’m convinced that the tension of forcing the gantry support against the carriages brings the screw closer to the rail than intended. At the middle of the screw, flexion lets that happen, even if it’s an undesirable force. At the end (front) the mounting prevents flexion, and the force is more than the motor can take.
My first (ever) try at a YouTube video is the description I made yesterday.
Set your video to unlisted and then we’ll be able to see it, your the only one who can see it in private
Let’s see if this works.
The only thing i can think of is that the machine isn’t square.
Have you brought this up with an email to support@pwncnc.com
Yes, you’re right about not being square. That’s what I hoped to show with the CAD drawing.
The gantry is a rectangle in which the top and sides are extrusions (no change in size is possible). The bottom dimension is defined by the X-extrusion length, to which we add two Y-extrusion widths, and the thicknesses of the rails and the carriages. The result of all of this is that the bottom is 4 mm shorter than the top. It’s not square because tightening the bolts that run through the gantry support and into the carriages pulls it out of square.
I suspect the solution is to place 2mm shims between the carriages and the dados in which they sit (both sides). My experiment with movement when even one side’s tension is released seems to indicate that.
Good video. It definitely shows the issue.
Definitely contact support.
Daniel (support) and I went through a process that could help others.
First, we made sure the Y front plate (and later the rear plate) are (briefly) able to move. That means releasing their bolts, but also being sure the weight of the Dominator on them isn’t a factor. Then we gently jogged forward, intending that the Y-screw (mounted to the plate) ease it to its preferred position. That gave another 3/8" of forward motion (before binding stopped the motor) but it didn’t provide normal movement.
Next, I measured the distance between the Gantry Supports in two places:
  1. Top. For me, this was 1458 mm. Since the Parts Manual says the Gantry extrusion is 1458 mm long, that makes sense.
  2. Bed-height. My measure between the Supports at this height was 1455 mm. If you add up the X-extrusion length (1284 mm) and the widths of two rails, two Bearing Blocks, two Y-extrusion widths and two Gantry Support Spacers, you get 1454 mm. So the measurement of 1455 also makes sense. However, it’s not the same as the top. It’s off by 3-4 mm.
So I supported the gantry on the left (where binding happened) while releasing the bolts that connect it to the bearing blocks. The Support sprung to a position where the Gantry Extrusion (at the top) holds it at 90 degrees, creating a 2 mm gap from the Bearing Blocks. Again, that makes sense if each side has half of the discrepancy that we measured.
I decided to shim, but not necessarily the entire gap. Although we realized the Support was being pulled out of square, and that doing so pushes the Ball screw closer to the center, we don’t know what distance between the Ball Screw and the Bearing Blocks is ideal. We just suspected that pushing the Screw by the observed amount was incompatible when the gantry is near its forward mounting location.
I inserted a 0.65 mm shim between the Bearing Block and the Spacer on the Gantry support. It made it possible to move the entire distance that it should. However the motor still sounded as if it were struggling. So I added another, making 1.3 mm of shim. This made both the movement and the sound normal. Being concerned about symmetry, I added 1.3 mm of shim to the same positions on the right. Although there was no change in movement or sound, an intermittent problem I’d been having with “Homing” disappeared. Now that I think about it, the “Homing” location is a second place where the Ball Screw is mounted (and can’t flex). I suspect the problem showed up as motor failure in the front and Homing failure at the rear.
Daniel has re-measured his machines and also found differences in the measures at the two heights, but he has not had binding problems. Still, I think we discovered that this could happen, and that some machines might benefit from placing shims. If you run into a problem with homing or actual binding on a new Dominator, share the measurements at those two locations with Support.
The 3–4 mm difference between the top and bed-height measurements points to the gantry supports being pulled out of parallel by the bearing-block bolts. Shimming between the supports and bearing blocks is the right place to start, but check the Y ball screw afterward: if the screw ends stay fixed while the support moves, the ball nut can be side-loaded even though the gantry is square. Jog the full Y travel slowly and watch or measure for binding at the front before final tightening; adjust the screw mounting plate if needed.
I agree.
After I shimmed between the bearing blocks and the block that has a dado (where they secure) the two measurements were not equal, but the binding that caused alarms ceased.
I continue to wonder whether milder resistance will eventually lead to harm, despite being too mild to cause an alarm.
