I need to know what the maximum width of a spoil board I can put on the dominator. Also what is the maximum width that I can surface with a 2" Bit? The width is something I need to know so I can plan attaching my AirWeights Slat system. Pic Attached
Also what is the overall machining boundary of the dominator?
@Chris. Thank you Chris. I have seen those measurements. But I need to know that I can attach the slats to a spoil board that has been surfaced first. The slat layout is 49" wide and I need an additional .8" on each side to attach T-track. So 50 5/8" min. This is because I plan to have AirWeights cut and mill special 1/4 inch parts to go under the slats so I can attach them from underneath. The slat cannot be attached from above. I hope this makes sense.
Since I have not received my machine yet, I cannot measure this myself and I was hoping PwnCNC could confirm that these measurement are doable after they assemble their fully functional Dominator. To have these parts made will be expensive and I do not want to have it done if they will not work.
The plywood in the photo is 50" wide and 48" deep. The machine itself has a 2" front overhang which allows for “edge” jigs of various styles as well as tool-storage.
@Daniel. Thank You Daniel. Is it possible to mount 50 5/8 inch width spoil board or will that interfere with movement? The setup I ordered is just like in this picture.
We have a gantry upgrade which is currently included with all machine orders.
The inside distance between them is 54.108"… thus anything smaller then that will work just fine.
