While the Leg Kit appears quite sturdy, it is also expensive. At $2127.00 it places it outside our budget. We would love to build our own table and use the funds saved to help towards an ATC if possible.
So, here is the question. Is there a set of plans for a DIY table that works with the Dominator Pro? If not, what specific dimentions and features would a support for the D Pro require?
In a word, there is not. Just a table would probably suffice.
Dimensions with an example table size can be found here: Dimensions - Dominator Pro
They is a PDF Attachment of the images, so you can print it out and scribble any ideas on dimensions ect.
You can use promo code CHRISS, it won’t work on ATC, but it will on the CNC.
Excellent, those provide just about all I need to design a table. 72”x72” will do the trick.
One last question. It looks like, from the drawings, that the end plates on the 4 corners are flush with the bottom of the cross bars for the bed. Is that correct, or is there any offset between them?
The Y plates are designed to be flush but only when you have the Bed Rigitidy upgrade.
Otherwise, the primary “bed” frame of the machine it sits roughly 40mm above the surface if it were sitting on a flat surface.
