VFD T1A/B/C Ports accessible?
Howdy!,
I recently purchased the 220v kit with a 220v pond pump for a Onefinity with the buildbotics controller. When it arrives, I am hoping to hook the pump’s power to one on the T1A/B/C ports to provide power to it when the spindle is turned on. Is this accessible/possible to on the VFD? Thanks!
When you get it, there will be an iot plug that goes into the side.
Pretty sure your not going to be able to power the pump from the vfd, but you can use the plug to connect an iot power strip, then whenever the rpms exceed ~5500 it’ll change the state of the outlets on the iot strip.
IoT strip
Wire sold seperatly.
Thanks for the reply! Check out Page 18 of the VFD manual, referring to T1 relay. T1A and T1B are normally open (configurable in settings) that are rated for 250V AC @<3A or DC30V <1A. Are those ports accessible if I remove the PwnCNC enclosure/case of the VFD?
I wouldn’t suggest opening it up, and wiring it in but you can check the power available in the run port when you get your VFD.
