Is there a trick to turning the regulator dials on the PE? I’ve tried turning them and they don’t want to budge. I tried pushing first, but can’t seem to do that. I’ve tried to pull them, but I can’t get a good grasp on them so I doubt that’s it. I haven’t tried using pliers because I don’t want to inadvertently damage it. Any help would be appreciated.
The way we initially configure these regulators is by taking a 3" piece of tubing that’s been folded over onto itself and zip-tied to keep the pressure.
Then activate that relay/solenoid sending are into the pinched off tube. From here we can adjust the regulator to the desired pressure.
Know that only one solenoid can be ‘charged’ at a time. So if what you’re wanting will happen in the middle of a tool-change… know it’ll likely cause you problems, however laser-air-assist… it is a perfect idea. .3mpa may be too much pressure for a laser though… so you’ll definitely want to lower that down.
Ah, they’re embedded in the enclosure, so you’ll need to take a wrench to gently pull on the knob. This will “snap” it out about 1/4". There’s a noticeable click.
After that you can turn the knob to adjust… then be sure to press the knob back in until you hear the click again knowing it’s locked.
