Masso work flow
New Dominator, first carve. Previously ran a carve with similar steps (minor changes) with no bits installed, no errors that I could see. This carve is a test with three bits. First is a .025 mill, making four 1/2" pockets, 1/16" deep. Second is a 9mm drill, centered in the pocket, 1/2" deep, last is a 0.25" drill, full depth of material (3/4" MDF). (preparing for threaded inserts).
  1. 1. Installed mill (which I call #22), Opened Tool Offset screen, ran auto zero on Tool setter. Saved Z offset
  2. 2. Found work zero with PwnCNC Touch probe. Ran internal probe within the probe’s hole. It found the center and correctly set the XY=0 (3mm away in both directions)
    3. Moved over a solid part of the probe and pressed red dot in the center of the square on the screen. Probe gently touched surface, rose only 1/8". I raised it higher, put probe away.
  3. 4. Pressed “Go to Work 0” (it did, keeping mill elevated)
  4. 5.Pressed “Cycle start”. Bit rotated in air, eventually descending but just barely making four shallow pockets on the surface. Finished, returned to the Bit change location (not Work=0, nor Tool Setter location…as I expected)
  5. 6.Replaced mill with drill (my tool #51, which has never gone through an Auto Zero cycle). Hit Cycle start. While spindle not rotating, machine drove bit down into the workpiece (no XY motion, just Z). “Errored” out.
I expected a couple different things. First, the Z=0 was too high above the workpiece. I’ll recheck the offset in the Settings, but I entered 0.39" (10 mm), which was what I measured the Probe depth to be.
Second, I thought that just after a bit change, the machine will go to the Tool Setter, determine the offset, then be ready to cut. This time it didn’t move to the Tool Setter in the XY axes.
What did I do wrong? Is there a setting that’s improper?
Disable “Only Auto Tool Zero When Manually Requested”
When you turn on your machine and home it, it’ll go over and get your offset for the current bit installed. Do not change your bit until prompted, have all your tools numbered in your CAD, and match those tool numbers/tools in Masso.
It is then safe to probe XYZ provided XY are currently setup for your bit.
Yes that is correct.
Perhaps if you took a video of an example job process and uploaded it to youtube and kept it unlisted, I’ll be able to give better feedback, but thats what I’m seeing based on what your saying. There maybe something there your missing that you dont know your missing which is why i suggest that.
Thank you.
I un-checked the “Only Auto Tool Zero when…” then homed the machine. Not surprisingly, immediately after homing, it headed to the Tool Setter place and started to descend. But there was no tool in the chuck, so I hit the E-stop.
-Is there a way to clear an E-stop other than turning off the Masso? Setting everything back to green isn’t enough.
-Is the usual workflow to chuck something into the spindle at the end of the day, so that it will have something to use at the next start-up? I’m thinking of something safer than a bit, such as a smooth piece of 0.25" rod, or a broken bit inserted upside down. Maybe most people use an actual probe, and set up the Touch Plate before switching to first bit they intend to cut with.
Chuck the bit that masso says is loaded. You can just rehome it.
Or you can just leave the last one in there. Personally i have a blank that i modified my post processor and appended a tool change at the end. i can choose to either have it load tool 1 or not.
Again do not change the bit unless prompted by masso (you can force the change if you’d like via mdi TxxM6 where xx = tool number)
Btw, this is the probe blank i use
I like your blank idea. Temporarily, I’ve used a 1/4" mill as Tool #1, but can replace that with a 1/4" blank when I have one. Since my first and last bits are often tapered (which isn’t suitable for defining X/Y=0 on a Touch Plate) it makes sense to begin with a blank and define those workpiece points at the beginning of a carve. Whether I finish a carve with a taper and switch to my “Dummy” before shut-down, or do so at the start of a day, I guess I should input the MDI line, “T1 M06”. I’m still fuzzy on the workflow that follows.
On my latest test, I had to hit “Rewind” before it would accept “Cycle Start”. It knew it was holding T1, and the carve required T22. I think I could make that switch before it asks me to, but (since it still thinks it has T1) it will ask me to make the switch either way.
I see how to request a movement to the “Parking” place, but not how to request a move to the tool change place. If I’m hovering over Workpiece XY=0 or over the Tool Setter, I’d rather not change bits. But if I change the Parking Place to somewhere closer to Machine XY=0, it’s too far for making a tool change. If I were confident that I knew where in the sequence Masso will spontaneously go to a Tool Change place, it would help.
That happens. Ive come to the habit to rewind - cycle start… its a struggle when i dont want to rewind, like when resuming a carve i stopped early.
Bad idea. Just tell it to do it via mdi, or do like I did and add it to your post processor. If you have vectric, I can help with post processor, if you dont, well I can’t with that.
Having manual tool change selected you can dictate where that is, mine is middle X, Y front. You shouldn’t go there manually to change a bit, just mdi a tool change. Since you brought it up, my park is in the back Y in the middle X to be out of the way, and I added a code to go to park at the end of my carve so that its out of the way. Again I have vectric, and this is customizable within that software, and I can do a write up to help if thats what you’re using.
It doesn’t spontaneously go there. It will only go there under 2 conditions… 1 you manually command a tool change via mdi, or a tool change is embedded into your file. Either way it will only go there when you request a tool change.
Outstanding. I also use VCarvePro. I didn’t know it could add the instructions you mentioned, and yes, I’d enjoy seeing how you do it.
So to recap (using the advice you just gave):
1.Turn on and Home. A blank 1/4" bit will already be in the collet as “Tool 1”. Masso’s routine will take it to the Tool Setter right after Homing.
2.Jog as needed to use the Touch Plate (and the blank bit) to determine the Workpiece XYZ=0. Jog enough to put the probe away.
3.Load the .nc file. Press “Rewind” then “Cycle Start”. Masso will notice it’s holding Tool 1, but the .nc wants Tool 22. It will move to the Tool Change coordinates and instruct to change the bit
4. Make the bit change (as instructed). Hit “Cycle Start” (but not Rewind?). Masso will go back to the Tool Setter now that it has Tool 22, determine its length, and return to Workpiece XY=0.
5. Hit “Cycle Start” again, Masso will do what the .nc asked from Tool 22, then come back to the Bit Change coordinates and request the next tool.
Outside the workflow
1. I’ll change my “Parking” position to somewhere out of the way.
2. I’ll learn how to tell VCarve to ask for Tool 1 at the end of each carve.
3. I’ll learn how to add instructions in VCarve to go to the “Parking” coordinates at the end of each carve.
Quick down n dirty video.
Correct, don’t need to hit rewind at this point, you’re already “in” the program.
2/3 its in the video i listed above.
Forgot to add… if you don’t already, save the toolpaths as multiple toolpaths as one file. They need to be sorted in the order of execution.
If done correctly order of operations might look like this: some things can be done out of order.
Create file in vcarve
Create tool paths
Save tool paths as single file to usb using your post processor of choice
Insert usb into masso
Turn on
Home
Touch off current bit
Change bit via mdi *as necessary… touch off probe
Load your file
Zero xy and z
(i jog around outside shape design making sure it looks right)
Rewind, start
Change bit as commanded
Green cycle start button
Touch off probe
Continues
Rinse and repeat till complete.
(Mine)
Goes to park
May or May not Change to tool 1
Return to park (i have atc and do not touch off after tool changes)
Rewind and complete
Power off machine, air, pe, water and spindle
Many thanks. With your help, the Dominator and I completed a toolpath with a mill and two drills. The video was too blurry to read, but the narration helped. “Parking” is now rear center of the field. I’d like to add a bit change (to a blank) at the end of every toolpath. Until I get there, I’ll rely on the MDI screen, where I’ll enter “T1 M06”.
Since the Masso workflow requires an instruction for bit changes, and initial probing needs a straight bit (which might not be a particular day’s first cutter) I plan to finish each session by putting a blank shaft in the spindle (my Tool 1). I couldn’t find one at the “Bits&Bits” website, where I’ve been getting mine, so I called.
They said they’d heard that a blank might be popular and are sending one to try. If it does the task, they’ll add that to their line.
