I installed my 110v spindle yesterday, xcarve, Where does the “drain wire” connect?
Hi @donholco, if you haven’t seen the following support article it may help you.
- Shield Drain - All of our cables are shielded to protect against EMI interference from other components. That interference must be “drained” into a ground rod to prevent any signal interference to the other wires. Wire this to a ground rod or someplace to drain interference away from the control cable.
The earth ground in your home electrical system should be connected to a ground rod.
https://support.pwncnc.com/kb/article/115-other-pwm-controllers/
Thx Eric, that’s how it’s wired. The spindle system works perfectly.
