Dominator Pro 2x2!
Guess who is finally ready to start assembling baby brother!
The last of the parts needed to put together a Dominator Pro 2x2 have arrived today and we are so excited.
Next week we begin assembly. It’ll be our smallest machine yet with a X565mm/22", Y544.6mm/21", & Z168.75mm/6.6"
It’s replacing our HDM as our primary metal mill and will feature SMW plates and vise(s?)… We’re sampling a 4.5kw air-cooled ISO32 ATC (not pictured), and 3Nm closed loop steppers.
I’ll have it slicing through aluminum and steel like butter in no time.
Okay, this is impressively outstanding! Please say this will support flood coolant, or at least a fogbuster?!?
o7
I don’t see why it couldn’t handle flood coolant, but I’ve never used a machine with it before.
Have you used machines that had it? What kind of requirements or things you think need to be accounted for me to confidently say yes to that question?
The closest I’ve come to cooling aluminum and brass was on my old Onefinity using a “poor man’s FogBuster” setup. It consisted of a cheap air/liquid mixing block (https://www.amazon.com/dp/B07HT1Y4BK) plumbed directly into my 75-gallon air compressor tank. The coolant side of the mixing block was simply dipped into a bottle of isopropyl alcohol. I ran fairly high air pressure (around 50 PSI), but with a very low liquid flow rate. My primary concern was chip evacuation first, cooling the cutter second.
The only other gantry-style machine I’ve personally seen that truly accommodates flood coolant by design is the Langmuir MR-1. When I say “accommodates,” I mean the machine bed is specifically designed to drain toward the center into a pass-through area where you would place a coolant tub, chip strainer, filter, and recirculation pump.
With that said, I think the following are at least good starting points for considerations:
  1. Provide multiple mounting points for accessories such as misting blocks or Loc-Line coolant hose assemblies, especially around the X and Z axes. Plenty of tapped holes would be appreciated.
  2. The use of actual fixture plates, which you mentioned, is perfect!
  3. Protect the screws and bearing blocks as much as reasonably possible. Personally, I would gladly give up inches of cutting area just to gain decent splash and chip shielding. I do not expect extreme measures, especially considering that even machines like the Langmuir often end up with coolant and chips all over the bearing blocks and ball screws. Still, the machine should at least be designed with the expectation that it will get wet and splashed to some degree.
Beyond that, I honestly would not worry too much about providing a factory base or enclosure for v1. There are already plenty of practical DIY solutions using plastic or fiberglass utility tubs from a home center, along with enclosures made from aluminum extrusion/T-slot framing or even wood.
OOoooo, cant wait to see the price and overall dimensions. Been looking for something to put under my bench and mill some metals.
This is very much an experiment at this point. If this proves to be as feature-packed as i’m hoping we may release it for purchase.
Depending on cost I might be really interested in beta testing this if thats a thing you do/need.
Any updates here? I am still very interested to see how this turns out.
Still hoping to hear more about this project.
This project is progressing although relatively slowly I’m afraid.
Dang, Im doing my best to be patient. :slight_smile:
Ok, finally back to building this bad-boy.
Adding an additional cross-support for strength, this should be here in a week or so, but it won’t delay assembly.
Sizing up the bed-frame to reuse the SMW plates i have. Later i’ll design some we can manufacturer ourselves… for now don’t want to waste these.
Finally got a large spot carved out for final assembly and initial testing of the Dominator Pro 2x2. Near the back of the warehouse with a few benches to keep things organized.
:partying_face: Cant wait. I’m still hugely interested in this build.
Progress moving fast now… we’ve got the main frame assembled and about to start adding electronics.
The Screw’s were not aligning just right… so i printed some spacers to prevent the float’s bearing from shifting.
Installing motors and making sure everything is accurate as i tighten things down and get it wired up.
