I have the foreman elite Gen 2 with the 80 mm air-cooled spindle. I have been trying for 6 months to get this thing trammed. Started off I had to completely reboot the system and enter the parameters by hand. Because the spindle jump to 24,000 RPMs immediately. So finally got that sorted out that took weeks with the support team. Now the tramming. Onefinity support says to use the Gen 1 procedure for the Gen 2 even though they’re explicit directions say do not use gen 1 for Gen 2 tramming. Their best advice is to tighten this or tighten that and to put a shim somewhere. I’ve got a dual gauge dial indicator I’m trying to use. Trying to shim the x-axis feet but I cannot get it perpendicular. Even with the assistance of two different AIS running the math I can’t get anything to work. At this point I can think of the one infinity and no other terms than junk.
Welcome, Art.
I trammed a Onefinity, but did it before there was a “Gen 1 or 2”. Here’s what I did, and what I learned:
Tramming is useful when your bit is spinning on an axis that’s tilted. On a CNC, there is a flat plane (your spoilboard) and it’s impacted by a line (axis) sticking up (your spindle and bit). If that axis is tilted, then the bit cuts deeper on the side you’re tilted toward. Similarly, if you use a Forstner bit on a tilt, it cuts on one side before the other.
When you have a wide bit, the tramming problem really shows. When your bit tip is only 0.005" wide, it doesn’t. So for some CNC operations, the tramming hardly matters. However, the bit you use when flattening your spoilboard is large, and if the tramming is off, it forms high and low lines. If you plan to use flattening bits for uniform backgrounds on bas reliefs, you might care about that more than if you’re cutting outlines for making duplicate pieces from stock or using V-bits on surfaces. You and I don’t want ‘tramming lines’ but if they’re small and you’re new to the hobby, you can probably focus on other stuff first.
I made a device with an arm sticking out of a rod, and a ‘feeler’ sticking down from the arm. Chucked into my spindle, I turned it by hand and lowered it until the feeler touched anywhere. While out of tram, further rotation made the feeler rise above the table. You can use the High School trigonometry where you got an “A” and decide how thick of a shim is needed behind your gantry mounting. Or you can just place one shim after another until you get what you want.
In the end, I still feel ridges when I make a spoilboard. But they’re so small that they have no effect on my carves.
The Onefinity was useful to me for 4 years. It would have stayed useful for longer, but they stopped supporting my “Buildbotics” controller, and the way they did that damaged my confidence in future support. So learn what matters to you in any CNC, then find the upgrade that helps you do the work you intend.
Thank you for the response David. I finally figured out where to put the shims and was able to get it to the point where I could only see a slight ridging in the spoil board and could just feel a slight Ridge with my finger nail. Was Evan able to cut a test sign tonight. I’ll take your advice to heart and stop overthinking and over complicating it.
Thanks again.
