Breaking Resistor Setup
I just added the PwnCNC breaking resistor to my Onefinity Elite Woodworker (MASSO) with PwnCNC ATC. In my testing I cannot see any difference with the resistor connected. What I see is that the VFD setting has a big impact on the spin down time, but the resistor being connected makes no difference.
I’m using the MASSO to turn the spindle on (Spindle CW) and off (Spindle STOP). I’ve got the RPM set to 24,000. I measure the time for the spindle with tool holder to come to a complete stop.
P0.0.12 Spin Down Time Resistor Connected
3.0 6 Yes
3.0 6 No
6.0 9 Yes
6.0 9 No
33.0 32 Yes
1.0 7 Yes
1.0. 7 No
I ran each of the test above at least two times. I also did a series of seven rapid start/stops. I would start the spindle as soon as the tool holder stopped spinning. After all of this testing the resistor it self is still cool to the touch with an ambient temperature of 72F.
Are these valid tests to see an observable benefit of the breaking resistor?
I would try to modify spin down in Masso’s spindle settings as well… on second thought that’ll just be a pause before/after setting
After a few exchanges with support, the conclusion is that the breaking resistor is fine. My system just doesn’t have a significant amount of excess energy that needs to be dumped into the resistor. The resistor was inexpensive and doesn’t require any maintenance. At this point it feels a bit like insurance. It doesn’t hurt to have it.
