2.2kWh Spindle Water Accessories
Greetings from Tejas,
 So I was a bonehead when I ordered my spindle and ordered without the pump (ultimately it was because I have a pump I use for my laser). But after thinking about it I was like, ok, lets just get a dedicated one until I can afford the dual chiller.
 I'm looking for links on pumps (that you have USED and approve of), and tubing. What tubing is actually best? I am generally a buy once cry once guy.
Thanks for your help!
Ock
If your buy once, cry once, our chiller is perfect.
I would not recommend using a shared chiller with a spindle and laser. The reason being the laser needs an active chiller with refrigerant so the coolant comes out cold. You dont want that with a spindle, and our chiller is a passive chiller where there is no refrigerant involved. The reason you don’t want an active chiller with a spindle is condensation, which would turn to rust given time.
Superthane either is that we love to have and use.
