I have used the chiller with my ATC for a while now and I have found that it does an excellent job at controlling the water temperature. The only issue I have with it is the fan noise. I do not want to listen to it when the spindle is not in use.
I have finally gotten around to trying to set it up for use with my IoT. Connections are very straight forward. I had thought that the IoT was intended to turn the chiller on when the spindle reach a speed of 6000 rpm and would be turned off when it was lower than 6000 rpm. I suspect I can accomplish this by plugging the chiller into the always off side. But the setup video said to plug it into the always on. I use a 220v whole shop cyclone dust collection so I have no need for the IoT to control it.
Can I set the IoT for this purpose?
