Masso Controller Emergency Stop
I looked around a bit and did not see what I might be looking for. I am hoping someone can help me out. I have an upgraded Onefinity Elite Woodworker and a 110v air cooled PWN Spindle. Things seem to work great most of the time. The other day I had an issue and hit the emergency stop button and the spindle did not stop spinning. It did not stop until I unplugged the power. I corrected my original mistake which caused me to hit the emergency stop and tried running again and hit the Emergency stop just to see if it would work, again it did not. I hit stop on the controller, and it turned off. Am I missing something here, shouldn’t the spindle shut off when i push the emergency stop?
It should provided your in auto and not manual mode.
I was in auto ode both times that it did not work.
Did you add the MPG and not switch the estop wires?
Without more information with what has changed or different, I’m really just grasping at straws.
EStop Wiring
MPG Pendant Information
You know, I did add the MPG right after i did the upgrade. I do not recall if i did or did not switch the estop wires. I will have to look at that this weekend. Thank you for your help!
