Adding a Masso controller to my Phantom cnc
Is it possible to change out my handheld controller to the new G3 Masso controller?
I believe it is yes… however it will depend greatly on how much of the existing machine (specifically steppers and homing switches) you’re wanting to reuse.
If you want to reuse the steppers, what kind are they? Masso has some really good documentation on which types are supported… open-loop and closed-loop seem to be the most popular. I haven’t dug into the servo’s support yet.
The proximity switches should be pretty straight forward… although ensuring you can get the wiring matched up and attach the correct connectors to get it wired in.
I believe there is a very strong chance it’ll work just fine.
