# "Tool Error" with New ATC Setup
**URL:** <https://forum.pwncnc.com/t/tool-error-with-new-atc-setup/3202>\
**Category:** Spindles and ATCs\
**Created:** [June 11, 2025, 3:56am UTC](https://forum.pwncnc.com/t/tool-error-with-new-atc-setup/3202 "2025-06-11T03:56:55Z")\
**Posts on this page:** 1\
**Showing post:** 2
<div class="post-metadata">
**Author:** ![Chris](https://yyz1.discourse-cdn.com/flex011/user_avatar/forum.pwncnc.com/chris/32/54_2.png) [@Chris](https://forum.pwncnc.com/u/Chris)\
**Post date:** [June 11, 2025, 5:22am UTC](https://forum.pwncnc.com/t/tool-error-with-new-atc-setup/3202/2 "2025-06-11T05:22:22Z")
</div>
There’s a problem with 5.09 and linear tool change. Upgrade your software and try again
> **[Version 5.09](https://docs.masso.com.au/getting-started-guides/Software/masso-g3/release_notes_5.09)**
> [@Masso 5.09 and ATC. Use at own risk](https://forum.pwncnc.com/t/masso-5-09-and-atc-use-at-own-risk/2701):
> I don’t know if its a fluke, a me problem or a Masso problem… But after upgrading to 5.09, while in linear tool change 2, it completely skipped the tool change and proceeded to go to the tool path which would have easily broken the bit, probably instantly. Fortunately the height on the tool installed was higher, so it didn’t reach the material work surface. I shot an email off to Masso about it, and said I’d record it when it was done doing what its doing, if I’m able to duplicate it. I notice…
 ![1000009209](https://canada1.discourse-cdn.com/flex011/uploads/pwncnc/original/2X/7/70508a326d6f57ebfb9ab370b398cb77bb6dea5e.jpeg)
_[View the full topic](https://forum.pwncnc.com/t/tool-error-with-new-atc-setup/3202)._
