I’ve been working on an add-in for Autodesk Fusion that will send NC files directly to MASSO G3 Touch over Wi-Fi. The basic idea is that one can send the NC Program to MASSO via a button in the MASSO tool bar or a context menu selection. See attached screen shots. In my testing everything is working well. Soon I’ll be looking to share a beta release with select users to get their feedback. If anyone here is interested please send me a message. In your message please let me know if you are using a Mac or PC.
I’m one of the few who don’t know what an NC file is, nor the objectives in sending from Autodesk directly to Masso. Is NC what I would have called a “.ngc” file? Is this a project that sets aside programs like VCarve? Is it primarily for 4th axis projects? Please assume I don’t know anything (since I don’t).
An NC Program file (.nc, Numerical Control) is where Autodesk Fusion writes your G-Code. G-Code is what tells CNCs, 3D Printers, and LASER engravers/cutters what to do. I haven’t used VCarve, however I believe its .ncg files are also G-Code (Numerical Control G-Code).
VCarve and Autodesk Fusion are tools to create tool paths that are then converted into G-Code (.nc, .ncg file). The Fusion add-in I’ve created does not replace VCarve. The add-in assists users of Fusion in transferring the G-Code file (.nc) to the MASSO G3 Touch.
There are two common ways of transferring a .nc file to MASSO G3 Touch
Thumb Drive: post file to disk, remove drive from MASSO, connect to PC, copy files, remove from PC, connect to MASSO.
MASSO Link Application: post file to disk, drag to MASSO Link, send file.
Love it! I was contemplating writing a thing that watched a specific folder and synchronized that with the Masso, but this I suspect may be more convenient still. Count me in!
The Send to MASSO Fusion add-in has been live in the Autodesk market place for a couple weeks now. I’m always eager for feedback from users. The add-in supports Mac and Windows.
A big update to Send to MASSO has just been released. This version adds optional advanced path definitions. Which provides powerful options for how files are organized on your MASSO.
Destination path built from fields:
Output Folder
Setup Name
NC Program Name
Tool Path Name
Date
Text
Send to MASSO is getting better thanks to the input of users from this forum. I’m always eager to received feedback.
