Documentation for conversions is robust, and many pages apply to the Dominator “Pro”, but not all. We would benefit from completion of the set-up guides that were partly completed when published in January 2026. Daniel is a busy guy, so I wonder whether he’d benefit from a small cadre of users who collaborate on creating a draft? Making user manuals (as for tech support) might be necessary, but it doesn’t bring in new business. 2-3 people sharing what we know, and how to avoid the mistakes we no longer make could help new users. If it helps PwnCNC at no cost, all the better. The prototype for my question is the business model at Woodsmith Magazine. There, the published product comes from 2-3 staff woodworkers writing down the project steps they used.
I’ve lately hacked my way into setting up homing for mine, and I’m not sure whether my ‘realizations’ are accurate enough to add to a ‘how to’ guide. Even if they’re errors, I won’t be the only person who makes them.
My first challenge resulted from loose wires on a proximity sensor. It had power to recognize adjacent metal, but not enough to send the info to Masso. I had crashes into the sensor and disagreements between Y and B sensors before figuring that out. A “How To” guide could include testing sensor function (red light on the sensor) and communication (“High” indicator on the correct line in Masso F1) before trying the first homing.
My next challenge becomes a question for folks here. Once homing worked, I left the machine in that position and quit for the day. Upon return, I started with homing, and right away had errors on two axes. I cleared the “High” indicators so that I could jog away from the sensors. I re-tested sensor function and communication (as above) and all worked. Now from a position well away from “zero” I called for homing, and everything worked. The ‘step back’ from a homed position is set at 0.1 inches.
Does this mean I should adjust some setting so the machine won’t try to get even closer to a sensor it already activated? Change the ‘step back’? Or just add to the “Homing How-To” that you don’t “Home” if you’re already home?
